System and Interfaces
SysAid’s usefulness and reach can be enhanced through integrations with other corporate applications and systems. With LDAP
integration, email integration, API, and more, SysAid seamlessly becomes a part of your corporate IT environment.
Upload end-user information into SysAid to let agents and end users access via their active directory passwords.
Automatically create new incident records from incoming emails, log all end-user responses within an incident or service request record, and update the record status when an end user responds. You can also reply from within the ticket, and the recipient will receive an email notification.
SysAid offers out-of-the-box SMS/ text message integration using leading service providers, with an option to add your own service provider. Choose which scenarios trigger text messages, such as monitoring alerts or unassigned high-priority incidents. Also configure text messages to include the details you need to understand the situation to which you are being alerted.
Integrate SysAid with your external applications and write your own code to create, retrieve, update, and delete SysAid entities. The SysAid API allows up to two login requests and up to 1,000 other requests – every five minutes.
SysAid supports the following databases: MySQL, and Microsoft SQL.
Provide effective and organized support to multiple companies, business units, clients, and locations.
We support several single sign-on credential providers. See our Marketplace for more information.
Import and update asset data using a CSV (comma-separated values) file. This capability allows you to easily migrate data from another system as well as set up integrations with external asset management databases.
View all the events that have occurred in SysAid, including (but not limited to):
