Trend detection
Recurring incident management groups issues
PROBLEM MANAGEMENT
Fix the root cause, once and for all
Automatically identify causes, prevent incidents, and deliver lasting resolutions with AI root cause analysis and problem management software built into your ITSM.
89%
first-time fix rate
Increase of 60%
touchless resolution
Decrease of 20%
lower MTTR
Decrease of 25%
fewer tickets
Root cause found.
Priorities clear.
Problem fixed, forever.
PROACTIVE RESOLUTION
Find the root cause, stop the repetitive cycle.
Gain visibility into a root cause analysis of problems for permanent fixes. No more workarounds, reigniting fires, and broken trust — get real solutions to every problem.
PATTERN DETECTION
Spot recurring and similar issues instantly
Save time with AI that links incidents, finds connections, automatically groups them into one root problem, and runs them through a known error database for quick solutions.
PERMANENT FIXES
Turn resolutions into lasting fixes
Don’t spend time on the same incident twice. Resolved problems become automated fixes going forward, until the root cause is found. SysAid AI learns and takes action, instantly.
SMART PRIORITIZATION
Work on the most important problems first
Auto-prioritize problems by severity and business impact to ensure your team’s time is going toward fixes that are the most costly and disruptive. AI prioritization you can trust.
DETAILED REPORTING
Easily access useful insights and reports
Keep your leadership happy with dashboards and reports that clearly show every root cause, fix, and change. Simplify auditing and get insights that drive decisions.
AI quickly surfaces the root cause
Connects problems to assets via CMDB
Auto alerts keep everyone in the loop
Standardize resolution workflows
Logs every action and keeps learning
FAQ
Finds the root cause behind recurring incidents and fixes it for good. That’s IT problem management, and it’s automated with AI in SysAid. Instead of closing the same ticket repeatedly, your ITSM clusters incidents, links them to one root cause, and turns the fix into permanent knowledge so your AI is ready to act and resolve the issue automatically in the future.
When looking at incident vs problem management, keep this in mind — incident management resolves the immediate symptom fast. Problem management goes further and fixes the root cause so it stops recurring. SysAid ITSM with built-in problem management software and AI root cause analysis links comparable incidents to one underlying problem, so your team fixes the cause once instead of the symptom every time.
Documents a root cause and its workaround so the next agent doesn’t start from scratch. That’s a known error. SysAid turns any resolved problem into a known error or knowledge article in one click, so your team has the fix ready the moment the same issue resurfaces.
Clusters related incidents, cross-references your CMDB and incident history, and surfaces the likely root cause automatically. That’s how SysAid’s AI runs root cause analysis. Your team starts every investigation with an answer instead of a blank ticket.
Runs root cause analysis, known errors, and change management in the same platform as your incidents and CMDB. Nothing gets lost between tools. SysAid problem management skips the integrations most vendors require and moves a fix from diagnosis to deployed change without leaving the platform.
Cuts recurring incidents by fixing the cause instead of the symptom. That’s the core job of problem management. SysAid clusters repeat incidents, prioritizes them by business impact, and turns the resolution into a permanent fix, so the same outage doesn’t recur.
Converts directly into a change request inside SysAid. That’s how problem management connects to change management, with no handoff or separate tool required. Every problem, root cause, and resulting change is logged automatically, so the full record is ready when leadership asks what got fixed.
