IT burnout is at a breaking point, and we have the numbers to prove it.
5 min read
IT Burnout
Ask anyone working in IT right now how they’re doing, and you’ll often get a version of the same answer: tired, overworked, and nearing their breaking point.
That feeling is backed up by data. According to SysAid’s State of Service Management 2026 report, 43% of IT professionals are currently struggling with IT burnout and workload pressure. More than four in ten people, across roles, industries, and team sizes, are at or near their limit.
This isn’t a morale problem that can be solved with a team lunch. It’s a structural issue that’s been building for years, and the 2026 data shows it hasn’t peaked yet.
Burnout is hitting every level of the IT org, not just the front lines
The common assumption is that burnout is a frontline problem—help desk technicians dealing with an endless ticket queue. System administrators fighting fires at midnight. And the data does confirm that these roles are under serious strain: sysadmins report burnout at almost 49%, and help desk technicians are nearing 48%.
But what the 2026 survey makes clear is that burnout isn’t staying at the bottom of the org chart. VPs of IT report the highest burnout rate of any role surveyed, at 50%. The people who are supposed to set the strategic direction are just as depleted as those executing it.
At the director level, the pressure shows up differently. IT directors cite skill gaps within their teams as their top challenge (53%), and CTOs flag knowledge silos (44%). These aren’t burnout in the traditional sense, but they’re symptoms of the same underlying strain: teams that are stretched too thin to build the expertise and institutional knowledge they need to keep up.
Why has IT work changed, and how has it worsened burnout?
One reason burnout is so persistent is that the nature of IT work has shifted, making recovery harder. As routine tasks get automated, what’s left for humans tends to be more complex and higher stakes. Every remaining ticket requires more judgment, more context, and more effort to resolve. The bar for each interaction keeps rising, but the time and capacity available to meet it don’t.
This dynamic creates a compounding pressure. Teams aren’t just doing more work. They’re doing harder work, with less mental space to do it well. When that pattern continues for months, burnout isn’t a risk. It’s an outcome.
Hiring more people moves the problem; it doesn’t fix it
One of the instinctive responses to a burned-out team is to grow it. Spread the load. Add capacity. But the 2026 data show this approach has a ceiling.
Small teams of fewer than 10 people mostly struggle with individual burnout, the classic “too much work, too few hands” problem. But as teams grow past 50 or 100 people, the primary challenge shifts from burnout to knowledge silos. Larger teams distribute expertise across more people, which creates more handoff friction, more time spent chasing down who-knows-what, and more coordination overhead.
The result is that you can hire your way out of individual burnout and into organizational friction. The stress doesn’t disappear. It changes shape.
The industries that have the highest IT burnout rates
Burnout isn’t evenly distributed. Non-profit organizations report the highest rates at 54%, followed by manufacturing and finance at around 51%. These tend to be environments where IT is expected to support complex operations on limited budgets, and where the gap between what the team is asked to do and what it has the capacity to do is widest.
Non-profits also report the highest rates of skill gaps, with 56% flagging it as a significant challenge. When teams are already stretched, the inability to build expertise or onboard new skills properly makes everything harder. Burnout and skill gaps tend to reinforce each other.
Construction stands out for a different reason: 56% of IT teams in the construction industry report significant resistance to process change, the highest of any industry. When an organization resists adopting new tools or more efficient workflows, the burden falls on people rather than being absorbed by better systems. That’s a direct path to sustained burnout.
Burnout won’t ease unless the conditions causing it change
The pressure on IT teams isn’t the result of a single bad year or a single difficult period. It’s the result of environments that have grown more complex faster than the teams managing them can adapt.
Demand keeps rising. Complexity keeps increasing. And the manual processes and fragmented tools that many teams still rely on don’t get any easier to manage as the environment around them grows.
The organizations that are starting to make progress on burnout aren’t doing it by asking people to work harder or pushing through. They’re doing it by reducing the volume of low-value work that lands on people in the first place, and by giving their teams the tools to handle what remains more efficiently.
That’s the direction the industry is heading. How fast any individual organization gets there depends on whether leadership treats burnout as a symptom worth addressing at the source.
Want to see the full picture? Download the State of Service Management 2026 report for the complete data on IT burnout, skill gaps, and how high-performing teams are responding.
Get the full report.
